12s Motor Alternative
Discussion in 'SAB' started by ChopsyWA, Apr 7, 2015.
By ChopsyWA on Apr 7, 2015 at 11:38 PM
  1. ChopsyWA
    Hey all,
    After giving a mate a go of my carbon G570 earlier this year which ended up in destruction, I bought a white kit to re-kit with the electronics that survived.
    I gave a Xnova 4025-1120 a go on 6s, but it wasn't for me (lacking power...).
    So after fixing the Xnova 4025-560 from the carbon kit it is now running sweet in the white kit.
    But now I am rebuilding the crashed carbon kit, and need a motor for it.
    I definitely won't be trying 6s again, but do not want what I already have (what's the point in exact duplicate power machines).
    So can anyone recommend something different to try, maybe a go for something oversize (not to SAB spec), with more grunt that won't be wasted with a massive weight increase? Maybe a 4030 or 4035 if it will create a different feel to what I have?
    It's either try a different motor, or rebuild and sell the airframe, or maybe just go the trusty 4025-560 but with the kit stretched to 620 (I do have the lynx stretch kit available already - any local Aussie reviews on the stretch?)
    While it's good to have a spare kit, with the white G570 currently the practice machine, I need to justify having it built taking up space in the unit I'm living in - so ideally I want it fly-able but different.
    As I write this I'm starting to think to give the stretch a go, but still the question of which motor?
    Cheers
    Chopsy
      Hi @ChopsyWA you need to see @3dmicks and @Manyc setup on the 570. 6S is always going to be underpowered on the 570 when doing hard smak. But when you up it to 12S with a descent motor it becomes a whole new beast. The XNOVA so far has been the motor of choice over here. I know @3dmick and @Manyc use the xnova in the 570 but i am not sure of the model number - they will advise i am sure. I have seen quite a few smak machines move and the 570 is a great helicopter and the xnova is also a great motor but you got to use the right combo. The 570 flys hard and is responsive. So far this is the best smaker out of all the goblins - Every 3d pilot here who has flown the 570 on 12S says its a keeper. Try the 12S motor in the 570 - you wont be disappointed. Stand by for some specs.
    2. 3dmick
      The XNOVA 4025 560 on 12s 2600rpm
      Is the way to go with 3300mah packs
      Pure smack all the way baby
      yep.. but you may need to tape down the packs if your using 65c packs.... also you can run this at a lower head speed.. people like around 2300.. till they try 2600 and go "WTF have i been doing!?!?!" you will need to up the motor pulley to get that high..
      @3dmick lets video one of your 570 flights so he has and idea.. :p
    4. ChopsyWA
      Thanks for the responses :)
      though it appears my post wasn't quite clear enough.
      I actually already have the Xnova 4025-560 running in my white G570 (up to 2650rpm), what I am chasing is recommended alternatives for something different for my other carbon G570 (which I may also stretch).
      Not really after a result where I have 2 x G570's exactly the same.
      I like Xnova, have them in all my heli's, though will try another brand if I can get more power. Or I put in a bigger Xnova (I don't have a problem with modifying the canopy).
      Has anyone tried a bigger motor?
      And as a side question, has anyone tried the Lynx stretch kit without problems?
      aahh @BladeBandit ran I think it was a 4035 in his.. but you had to cut the canopy..
