Notice Fusuno Releases New Accessories, Canopies, And More
Discussion in 'Industry News' started by HeliGods, Apr 3, 2014.
By HeliGods on Apr 3, 2014 at 10:23 PM
    The hard working never stop. Team Fusuno have some great products recently released. From canopies to rotor blades, Fusuno has what you are looking for. Click through to get the details for these new releases.
    Canopy cover Blade 500X (Black & Red)
    FUP-B500XBKR
    $8.00
    Product Details
    The canopy cover is custom-designed to protect the canopy from scratch during storage or transportation. It also helps prevent finger prints or dust on your beautiful canopy clear coat. The canopy covers are carefully handcrafted to perfectly fit the canopy shape. It has 2 small pockets at the canopy tails to custom fit the canopy so it is not easy to slip out. The material is ultra soft and the linings are carefully sewed to ensure the canopy cover does not shink when putting on the canopy. This could be one of the best investments for your beautiful airbrush canopy.
    Also available for:
    Blade 550X (FUP-B550X-BKR) $10.00
    Fusuno Rocket Airbrush Fiberglass Canopy Goblin 500
    FUC-GB500-01
    $61.20
    Product Details
    Fusuno canopies are made with highest quality resin and fiberglass material to provide strong but flexible canopies. It helps prevent cracks that is normally seen in other canopies that are using lower quality material. All paints and clear coat are automobile grade provide great look, Great design at bargain price.
    Fusuno Wolfie Airbrush Fiberglass Canopy Goblin 500
    FUC-GB500-02
    $61.20
    Fusuno Alabama Airbrush composite Fuselage Trex 150 Goblin style
    FUC-T150-GB01
    $27.95
    Product Details
    Fusuno is pleased to offer all new composite fuselages in Goblin style for Trex 150 helicopters. These fuselages are very light weight thanks to the careful use of composite materials, and are full airbrushed. Refresh your hobby with a cool new appearance for your helicopter.
    Product Include:
    -1pc x FUP-PLC04 Plastic clamp support Trex 150 fuselage.
    -2pc x PHS-145 Pan Head Screw M1.4 x 5.
    Also available in:
    Cetonia (FUC-T150-GB02)
    FUSUNO Samrock Airbrush Fiberglass Canopy Raptor G4
    FUC-RG4907
    $70.00
    Also available for:
    Raptor 90 3D (FUC-RT905)
    FUSUNO Neon Yellow vertical fin KDS Agile 5.5
    FUF-FN5501-YL
    $7.99
    Product Details
    Fusuno Neon Frame Kits & Parts – When Different is Always Better! Looking for a way to add a whole new look to your RC helicopter? Tired of drab black and endless other “carbon” kits & parts out there? Fusuno has your answer with Neon Frame Kits & Parts, which not only add a whole new look to your helicopter, but greatly aid in visibility, which can make or break any flight!
    Designed to utilize the stock hardware via your helicopter, these frame kits & parts make it easy to upgrade without the fuss & bother of special parts & pieces, allowing you to easily replace items with stock hardware.
    Constructed of durable, high quality G-10 FRP (fiberglass reinforced plastic), and available in multiple exciting & bright colors, these Fusuno neon parts are treated with a hard coated dye that is not only strong, but will last long and resist scratches & chips.
    If you’re in the need of a change, check out Fusuno’s exciting line of neon upgrades for your RC helicopter, and add a unique look to your RC machine that will definitely stand out from all the rest!
    Also available in:
    Neon Orange (FUF-FN5501-OR)
    FUSUNO Neon Yellow Main Frame Set (Left + Right) KDS Agile 5.5
    FUS-FR55-YL
    $39.99
    Also available in:
    Neon Orange (FUS-FR55-OR)
    Fusuno Stratovarious Airbrush Fiberglass Canopy Goblin 500
    FUC-GB500-03
    $61.20
    Fusuno Wolfie Airbrush Fiberglass Canopy Goblin 630 Competition
    FUC-GB630C-01
    $85.50
    Fusuno Stratovarious Airbrush Fiberglass Canopy Goblin 630 Competition
    FUC-GB630C-02
    $85.50
    FUSUNO FPV Antenna / Helical Axial Mode 5.8 GHz RHCP
    FUM-FPV05
    $34.99
    [​IMG] [​IMG] [​IMG] [​IMG]
    Product Details
    USAGE: Increased video range and clarity
    DESCRIPTION:
    Fusuno is pleased to introduce our helical antenna, designed for increasing video quality at maximum range. The helix is supported by a precision polycarbonate frame. Each antenna is hand tuned and impedance matched giving you a minimum of 12dBi return.
    The antenna structure achieves a beam width of approximately 38 to 60 degrees. Our helical antennas have a minimum 12dBi gain across the entire 5.8GHz band.
    Recommended for use on long range FPV video receivers FPV, and combined with a Skew Planar Wheel Antenna on the video transmitter will achieve maximum FPV range.
    SPECIFICATIONS:
    Frequency Range: 5725-5875MHz
    Impedance: 50Ohm
    VSWR: less than 1.5
    Gain: 12dBi
    Horizontal 3dB Beam Width: 38°
    Vertical 3dB Beam Width: 38°
    Front to Back Ratio: 15dB
    Polarization: RHCP
    Radiation: Omni
    Maximum Power Input: 50W
    Lighting Protection: Direct Ground
    MECHANICAL SPECIFICATION:
    Connector: SMA female and male
    Also available for:
    Fatshark and ImmersonRC (FUM-FPV06)
    Fusuno 325mm Carbon Fiber Main Blade
    FUB-CFB-325BK
    $12.00
    Product Details
    Fusuno is pleased to introduce our high quality, superbly finished, carbon fiber main blades for 450 size helicopters.
    Designed for use on flybarless helicopters, the airfoil and weight balance of these blades has been optimized to give you the best cyclic response and control of your model. These blades also excel in 3D flight characteristics when used on flybar helicopter models.
    Using high quality carbon fiber and epoxy resin, our blades have high torsional strength and stiffness. Your helicopter will feel agile and responsive, at high or low rotor speeds.
    You won’t find better blades at any price!
    Specifications
    Material: Carbon Fiber
    Length: 325mm
    Width: 33mm
    Weight: approx 22g (single blade)
    Hole Diameter (Bolt): 3mm
    Also available in:
    430mm (FUB-CFB-430BK) $23.00
    Authorized AlexMos 3rd axis optional Yaw Expansion Board (support 2 axis gimbal controller)
    EPT-003
    $65.00
    Product Details
    3rd axis optional Yaw Expansion Board.
    Support Authorized AlexMos V2.3b5 Firmware Simple Brushless Gimbal Controller w/ IMU.
