Question? Grease!
Discussion in 'MS Heli' started by Lycean, Jan 15, 2015.
By Lycean on Jan 15, 2015 at 3:26 PM
  1. Lycean
    Lycean New Member
    Looking through the manual for the Mini P kit I notice that it calls for grease on some of the bearings. What's appropriate to use?
      I use tri flow grease on the thrust bearings... tri flow oil on the main shaft and tail output shaft.. and since your running the stock kit.. scorpion motor oil for the motor.. also a lot of people use silicon spray on the belt...
    2. Lycean
      Lycean New Member
    3. ArgyPak
      ArgyPak Active Member
      Where do you get the triflow from?
      Got mine from rcbits and some from Qikazz
    6. simon
      I ordered mine from the states when the dollar was 1.05, arrrrr..... those were the days
    7. Manyc
      Yeah I know.. now it hurts even buying local as the prices reflect the dollar
      I use thin air on the belt bearings! Silicone spray on the belt. I use lithium greases on the thrust bearings..Provided you don't run your belt too tight the belt bearings should last a while.
    9. Lycean
      Lycean New Member
      Hobby stores seem to be out of stock of Tri-flow synthetic for some reason, but I see that quite a few online bike stores sell it. Finish Line Teflon Grease also looks like a good fully synthetic too. Might have to see if any local bike stores have any in stock.
      In looking at all this I came across this article which has some good information in it and may be of interest to others: http://forum.heliguy.com/lubrication-dos-donts-whats-and-whys-t35792.html
      • Informative Informative x 2
