Notice Maiden Flight Of A Beautiful Scale Heli With Chris Reibert
Discussion in 'Industry News' started by HeliGods, Apr 2, 2014.
By HeliGods on Apr 2, 2014 at 10:44 AM
    Chris is a busy man, but he managed to get the maiden flight done for his Bell 429 Super Scale from RC Aerodyne. This heli is a beauty. Continue through to view the maiden flight. Awesome job with the build Chris.
    Bell 429 Super Scale Maiden Flight by Chris Reibert
    Click here to view the embedded video.
    Maiden flight on my Bell 429 Super Scale from RC Aerodyne
    Sorry it took so long I’ve got so many projects going on…
    SPECS:
    Body length: 1650mm
    Length incl. rotors: 1920mm
    Width: 355mm
    Height: 480mm
    Main rotor diameter: 1560mm
    Main blade length: 700mm
    Tail rotor diameter: 280mm
    Tail blade length: 105mm
    Main shaft diameter: 12mm
    Tail shaft diameter: 5mm
    Spindle diameter: 8mm
    Drive gear ratio: 1:13.8:3.9 ( 13.83:1 )
    Battery compartment: 2x 60x60x180mm
    Requires
    Motor:* 1x 750MX 500KV brushless outrunner, 12S capable
    Speed controller:* 1x 120A brushless, 12S capable
    Servo:* 3x metal gear cyclic, 1x 9g metal gear tail servo
    Battery:* 44.4V 5000mAh 35C+
    Flight time: 7-10 minutes
    Takeoff weight: 7200g
