Build Info Mini Quads
Discussion in 'Multirotors' started by Manyc, May 26, 2014.
By Manyc on May 26, 2014 at 1:03 PM
    Mini Quads seem to be all the rage... small nimble, can carry full FPV gear, and cheap to crash... since I have a disco pro and am scared of breaking it, since the main frames are very expensive.. I thought I would give one of these a shot...
    electronics are in... just need to frame and camera now...
      Cool man looks good what is It?
      it will be a bok230RE racing min-quad.. lot of people are using sunnysky motors and dodgy flashed HK esc's... but being in this hobby I have learnt.. buy cheap by twice... hence the T-motors
      the frame is done by a guy in NZ, who's doing a masters in design, and his theasis is quads... heard some good things about them... the frame is G10, not CF, armes are replaceable... and its only $60usd...
      not power distribution board... will have to work something out...
    3. The Dude
      Whats the cost of the whole thing going to be ... I'd like to try one, but dont have a spare 2 k lying around..
    4. Manyc
      I have the googles and that, so I dont have that cost... the motors esc Fc and all in the pic cost $450, $60USD frame, $45 camera, +vtx
      so about $600... but I have also gone your high end stuff.. if you wanted to go cheaper... you can go some $10 Hk ESC and firmware flash them with blheli and go sunnysky motors.. which would take $150 off the cost...
    5. Ben
      Ben Member
      Looks good mate, I'm finding myself watching the Blackout videos more and more these days. I reckon a little mini would be great fun.
    6. Manyc
      I was looking at the qav 250.. but hearing good things about the frame... also separate arms... I don't want to replace a frame because of an arm
    7. Ben
      Ben Member
      What flight controller are you going to use?
    8. Manyc
      Cc3d... open pilot...
      Ok been a while but here are some basic pics...
      [​IMG][​IMG][​IMG][​IMG]
      As you can imagine it's pretty tight getting it all in... there was a total of 6 mm of height for escs I ended up putting 2mm spacers in to give me some extra room..
      The kit came with Phillips head screws... I swapped them out... connect all the esc to one 4 mm bullet connectors...
      I did a test hover in my garage at 1am Thursday... was stable enough... but thought it was a bit gittery...
      Anyway started cleaning up wires when I noticed a few screws I had not tightened pretty much at all... explains the gitters... would have been causing huge vibrations....
      I'll put up some pics when I have it all together without the fpv gear as I want to fly it a bit first and make her fly hire I like before adding the gear... that said fpv gear has been wired up and tested.. Using the 5v power from the vtx and using a step up to make it 12v for the camera..
    10. Manyc
      Ok... test fpv flight completed... light was pretty poor and it was windy but it flew well... for those familiar with the MRCHC field I even split the trees with it...
      Will see how it goes with better light but overall I'm happy.[​IMG][​IMG]
      Being the first person to witness its flight, I must say that I am impressed. It flew very well. The video was also amazing...
    12. Manyc
      Ok... this thing is awesome... with the CC3D in what they call rattitude mode, its a bomb... basically it self levels of the sticks are near mid stick and switch to rate mode after a certain throw... Since I was working from home today, thought I would get in a quick FPV... and by the second flight I am flying between trees and along a path behind me... slowly I admit... but man it was fun.... and since its so light and cheap props... I'm not to concerned about damage...
    13. smakmeharder
      So all up that thing cost 600... plus you would need some fatshark goggles and receiver I imagine?
    14. Manyc
      The goggles are the killer... as I said you could go hk esc and flash them with blheli - $50
      Sunny sky motors - $100
      Cc3d board - $110
      Props - $16
      Rx - $70
      Vtx $50
      Couple of packs.. $50
      Fpv camera - $50
      Frame $100. Or go hk for like $20
      Decent antenna $75 optional
      Fatsharks -$500
      You can go a monitor but it's not the same...
      Total excluding goggles
      Yep about $600..
      Tho I spent $300 on motor and esc not $150
      Plus I already had the rx, vtx, goggles and packs
      If you get one that takes only a board cam I have one spare...
    15. 5Fidy
      Hobby king sell goggles for $280
    16. Manyc
      True... but you'll need to buy the vrx module for the goggles and a battery as they don't come with then
    17. Manyc
      Ok.. here is pretty much the first flight FPV with the bad boy...
    18. The Dude
      nice dude, i like it..
    19. 3dmick
      That's cool mate I was waiting for the crash in the trees
      That was so funny lol
