Question? Mini Vbar Software Help
Discussion in 'Vbar' started by Stuart, Jan 11, 2016.
By Stuart on Jan 11, 2016 at 8:30 PM
  1. Stuart
    Ok just purchased Brents E6. It has a mini vbar. I no nothing about vbar.
    What do I need to set up the unit?do I need to buy software ?
      Dude just download 5.3 software
      And away you go
      Here is a 12 part video series on the vbar setup.... starting from the first video here. Hopefully this will help @Stuart
    3. Stuart
      Thanks guys will proceed to download and educate
      It's pretty easy. The software pretty much walks you through the setup procedure.
    5. Stuart
      Thanks guys, downloaded and installed. Will put it to the test on the weekend.
      I have a question:
      What's the difference between HH and Rate mode in tail setup?
      I've been looking online, but explinations I see are vague at best.
      I'm running my 450 in HH mode right now and it seems to be holding well. What is the purpose of rate mode?
    7. Beaver
      Never mind...... I found the answer. Sounds like I need to stick with HH mode. (No pun intended) :D
    8. Manyc
      Yeah head holding mode will make the tail try and keep the nose pointing in the same direction... Rate mode only cares about the input.. Won't try and correct...
      I have put the tail in rate mode to get the optimal tail mid point.. Where the tail in middle stick has enough angle to counter the torque of the blades...
      It's not important... But I do it when I can be bothered when I'm doing a setup
    9. Beaver
      What I get out of it.... Rate mode makes Heli react more like a plank where the tail tends to fall behind opposite forward or banking movement, and is more suited to scale type flying.
      I also read that some prefer to setup tail with rate mode, and then switch to HH once setup is optimized to their preference...... as you described.
    10. Beaver
      (Palmface) Duh..... rate mode.... basic rudder and counter-torque with no gyro. I thought there was more to it. :rolleyes:
