Build Thread My First Logo And Love It.....
Discussion in 'Mikado' started by Ozzy Mozzy, Aug 9, 2016.
By Ozzy Mozzy on Aug 9, 2016 at 7:05 PM
  1. Ozzy Mozzy
    It's the old Logo 600 with the SX head, pinion support, carbon tail box and quick uk tail hub and grips...
    With a little research and some help from Dennis aka Thunder Fighter, I decided to set this up as a 6S machine.....
    Motor: KDE 1100kv
    ESC: Hawk 120
    Cyclic: Futaba BLS255HV
    Tail: BK DS-7005HV
    FBL: Full size Vbar with VBC Sat
    Lipo: 6s 5000
    Blades: Edge 600
    Maiden was last weekend and it went perfect, Head speeds ending up at 1400, 1600 & 1800 With a mix of 1400 and 1600 I got just over a 4 minute flight and had 50% left in a 5000mah pack
    1. Ozzy Mozzy
      Ah yep... Did a good job hey
    2. Ozzy Mozzy
      Picked up another complete Air frame... so now the rebuild begins....
      Changing some things around. Im taking the Futaba HV servos out and putting them in my TDR. I have some Align 6V servos to go in the Logo and a Heli Jive 120, using it's BEC as it's limited to 6V..........
      The TDR will get the Futaba HV servos as it's got the Jive Pro which has a 8V BEC
    3. Ozzy Mozzy
      Finally got the smashed up Logo 600 all fixed up ready for this weekend...
    4. Ozzy Mozzy
      Just installed some Protos 700 magnetic canopy mounts that I got from @ZEN RC to my Logo 600.... damn they make it so much easier getting the canopy off and on...
    5. Ozzy Mozzy
      Wow setup couldn't get any easier..... I actually feel like I missed something lol
      Hopefully get out on Saturday to try it out....
    6. Ozzy Mozzy
      Yesterday afternoon I put 3 packs through the Tribunus and noticed the ESC Temp gets up into the low 90’s.
      So for the Logo 600 on 6S I think esc fans will be on order.
      The only other thing I have noticed is the HS seems off, I have the correct gear ratio in it but I sounds like it’s a lot higher than the HS I had put in.... so I’ll have to Tach the head I think......
      I’ll be getting another one, it will go on the Diabolo 550......
