MSH-Heli Protos 380 Evoluzione Pre-order Pricing Released
Discussion in 'MSH Heli' started by The Informer, Jun 14, 2016.
By The Informer on Jun 14, 2016 at 10:03 PM
  1. The Informer
    The Informer Administrator
    The MiniProtos 380 With Brain2 Mini Pre order prices have been announced. Prepare to spend around 449.99 USD for this little bad boy. Remember it does come with a gyro!
    Pre-order: Expected ship date 6/29
    The Protos 380 takes the legendary Mini Protos design DNA forward to incredible new levels of flight performance, durability, and technology. MSH has leveraged over a decade of airframe design experience and customer feedback to create something truly amazing. Designed from the ground up to break performance barriers and deliver a new experience not yet seen in this size helicopter.
    The Protos 380 is designed with light weight in mind, while delivering an extremely strong and robust airframe that can take abuse flight after flight. The design is very low parts count, and extremely fast to repair, keeping you in the air. The use of mixed materials including carbon fiber, aluminum, composite plastics to optimize every aspect of the design.
    The future of the 380mm helicopter has arrived, and with it a new legend is born.
    Twin Belt Transmission
    The Protos 380 implements a robust twin belt transmission, with auto tail belt tensioner. This translates into thousands of maintenance-free flights and whisper quiet transmission. With the lack of gear mesh, the Protos 380 can handle huge power, while delivering it with no transmission noise. A robust one way bearing assembly is located in the main pulley assembly. The low drag setup allows great autorotation performance in a small package.
    Unique Belt Tensioner
    OTHER PARTS NEEDED FOR ASSEMBLY:
    Just incase you were not aware these are the parts needed for assembly:
    • 3micro size swash servos, 1 micro or mini size tail servo
    • Main rotor blades (385mm max)
    • Transmitter/Receiver
    • Motor (2820-890kV, 2618-1360kV for 6s)
    • 6s LiPo (1300mah-1800mah)
    • ESC (60A typical)
    THE MANUAL CAN BE DOWNLOADED HERE
    1. maingeer
      maingeer Active Member
      nice thank you
      The price is not too bad considering a new design. I think the Goblin is not way overpriced for what it is - as many people claim (all things considered). This heli should theoretically be very very responsive due to less weight.
