Removal Of Hex Screw With Torx
Discussion in 'General Subjects' started by utrinque, Jul 30, 2015.
By utrinque on Jul 30, 2015 at 3:56 AM
    From time to time we succede to damage head of hex screw.
    I removed such screw with torx:
    First use strong iron to heat up screw and weaken threadlock.
    Use small hammer to place torx in damaged hex head.
    Unscrew...
    I hope this will help.
    I learned about screw extractors but they are usefull for bigger screws.
    Another solution:
    You can try also use drill if it can rotate counter clockwise.
    Good luck...
      Ah yes.... I have to use that trick occasionally in my automotive work.
