New Sab Goblin 380 Swash Leveling Tool / Partial Fail!
Discussion in 'SAB' started by The Dude, May 19, 2015.
By The Dude on May 19, 2015 at 2:42 PM
    Great for a quick setup but not much good for doing high and low leveling on the swash !
    1. Kyle Orrock
      Kyle Orrock New Member
      To be honest with the 380 there is no need to do a high and low level if u are using arm of the correct length and a good FBL unit it will compensate for the tiny amount it could be out
    2. The Dude
      True, if a good FBL unit it will compensate for it, then we don't need to be very fussy with leveling the swash at all.. However i personally like my setups to be spot on for top and bottom, it makes a difference, especially on the smaller heli's ...
    3. 3dmick
      I just used a bearing that fits on the main shaft works fine
