Build Thread Sab Goblin 500 Build Thread
Discussion in 'Sab' started by NevErSn0w, May 8, 2014.
By NevErSn0w on May 8, 2014 at 9:41 PM
  1. NevErSn0w
    NevErSn0w Active Member
    hey all, got a goblin 500 coming my way thanks to the boys over at ZenRC and will be doing a build thread and time lapse over the time of the build! if you have any questions let me know and ill try my hardest or ask kyle at http://www.zenrc.com.au/ask-kyle-article/
    if anyone has any tips and tricks for the build let me know as im always up for advice!
    here is the setup:
    Goblin 500 Red kit (http://www.zenrc.com.au/product/goblin-500-redwhite/)
    Quantum 4120-1200kv (http://www.zenrc.com.au/product/quantum-outrunner-brushless-heli-motor-4120-1200kv-goblin-500/)
    BK DS-5001HV Cyclic Servos (http://www.zenrc.com.au/product/bk-cyclic-servo-model-5001hv/)
    BK DS-7005HV Tail Servo (http://www.zenrc.com.au/product/bk-servo-multi-size-digital-tail-servo-model-7005hv/)
    Castle Creations Talon 90 ESC (http://www.zenrc.com.au/product/castle-creation-talon-90-25v-90-amp-esc/)
    Ikon FBL unit (http://www.zenrc.com.au/product/ikon-flybarless-system-polarity-protection-feature/)
    thanks for looking, the heli is due monday so will start the building tuesday! :)
    Cheers guys
    Darcy
    1. NevErSn0w
      Tail rotor done! :)
    2. josh
      josh Active Member
      looks good
    3. NevErSn0w
      Cheers man!
    4. NevErSn0w
      Okay, so wont be able to continue the build until 7:30 tonight :( school till 4 then to take the siblings to hockey, not much left to do really, attach tail to boom, boom to frames and a bit of wiring then she'll be ready for maiden :D
    5. ZEN RC
      Coming together well I see. Take your time and enjoy it Darcy!!
      Wow I must say that the black and the white looks quite striking!
    7. ZEN RC
      It does doesn't it. Looks even better in real Life.
      If we can convince Josh H to come to the Queens Birthday fly, we can all have a good look.
    8. NevErSn0w
      Okay, I have some pics for you! :D
      I didnt get pics of the last 2 stages as my phone was flat and mum had my camera :(
      [​IMG][​IMG]
      More coming
    9. NevErSn0w
      Got a fix for your problem mate! Its been pestering me and have found a fix, not surr if this will effect anything but all I did was found a shorter bolt of the same diameter and put that through, the spacer that you put between servo horn and ball link can then be removed leaving you with a couple mm clearence!
      Here is a pic
      I measured it and it misses by 3 mm or so :D perfect
    10. jockstrap
      Interesting Darcy..
      Did that increase the distabe between the ball link and the anti-rotation bracket mount ? or to the servo case? - as there looks to be only about 1mm gap not 3mm
      Whe distance to do have the ball link out from the center of the servo now?
      ie: distance from center of servo arm screw to center of ball link screw
      Also - what servo arms are you using as it's hard to find ones that fit well.
      PS: I updated my original post picture with a blue arrow to make sure we are talking about the same gap... can you have a look at the pic again please and tell me if that's what your solution fixed?
    11. ZEN RC
      Awww - it looks like the Speed had a baby :rolleyes:
    12. ZEN RC
      A pretty baby, but a bay nonetheless.
    13. NevErSn0w
      Ahh, you and I were talking about a different problem! :p aha
    14. NevErSn0w
      Ehe yeah, it does! :D keen to fly them both! :D
    15. NevErSn0w
      Setup 1/2 done will finish when I get back home... time for a maths test
