Question? T-rex 700n Fb Roll Rate
Discussion in 'AccuRC SIM' started by HeLiAdIc, Aug 4, 2014.
By HeLiAdIc on Aug 4, 2014 at 5:28 PM
  1. HeLiAdIc
    HeLiAdIc Member
    The T-Rex 700n FB roll rate is horrible and I can't seem to improve it, any tips to improve? because at the moment it rolls like a pig:confused:
    1. Jeff_Bradley
      Is that on 3G?
    2. HeLiAdIc
      HeLiAdIc Member
    3. Jeff_Bradley
      What FBL unit are you running so I can recommend an adjustment
    4. hardsy
      hardsy Member
      It is a flybarred Heli @Jeff B
    5. Jeff_Bradley
      Oh I forgot they still exist, in that case I would start increasing the travel adjust in the elevator channel
    6. simon
      I also think there are a few mechanical adjustments you can do on the arms
    7. HeLiAdIc
      HeLiAdIc Member
      Thanks for your reply's guys but I have tried all those settings.:confused:
      Oh and its the flybar vers.
    8. Jeff_Bradley
      What cyclic pitch are you running?
      no flybar weights, lighter paddles
    10. HeLiAdIc
      HeLiAdIc Member
      This is all within accurc and there is no selection for lighter paddles or weights. I guess I'll have to submit a support ticket on the web site.
    11. HeLiAdIc
      HeLiAdIc Member
      12 bottom and top.
      Put in negative expo in the transmitter
    13. The Dude
      up the pitch also ..
    14. HeLiAdIc
      HeLiAdIc Member
      Thanks mate I'll give that a try when I get home from work.
    15. Stephen
      Stephen Member
      Do the FBL test -> hold max pitch and then give full aileron deflection and tune the setting in your Tx to get 8 degrees pitch in the roll.
