HV and easy programming for your 700-800 class helicopter.
V4 with Anti-Spark relay, and easy setup using the ProgCard II. Lots of unique features sets the bar for high end ESCs. Auto motor timing, or manual adjustments in 6 steps. Overloading/temperature warning. Forward and reverse drive, or programmable forward only. Up to nominal 51.8 volts.
Features:
- Max duration at 160A good cooling. Burst (5 sec) 230A w/ heat sink.
- 4 to 14s LiPo.
- Undervoltage detection can be switched off.
- Optocouplers.
- Automatic timing, or adjustable in 6 steps.
- Integrated anti-lightning.
- Over temperature / over-load warning.
- Soft start can be individually adjusted.
- Speed regulation (governor mode).
- Active free-running, thus part load indefinitely.
- Normal EMK brake adjustable in 3 steps.
- Infinitely adjustable F3A brake.
Read more on this product here.
Notice Yge 160hv V4 (opto) Esc
Discussion in 'Industry News' started by HeliGods, Jul 4, 2014.
