Does Our Beloved Heli God Father.....
Discussion in 'The Chat Room' started by Mark Mickels, Aug 24, 2014.
By Mark Mickels on Aug 24, 2014 at 6:13 AM
  1. Mark Mickels
    offer vibration pardons? I'm stuck in vibration purgatory at the moment with my T-Rex 500. The bird has never been crashed and suddenly there is a vibration issue. I put on new tail blades, new tail box and blade grips, took the head apart, took the motor apart and checked the bearings, replaced the gears and the bearings in the boom box. The thing is still vibing, and I really could use a little divine intervention at this point. HGF, I'm about ready to throw it at the wall! I could have built two new kits in the time I've spent tracking down where the vibes are coming from!
      Maybe a bent torque tube Mark
    2. Mark Mickels
      I've got one on order. I've checked everything else and replaced enough stuff, so It has to be the TT. The bird has never been crashed, so I don't know how the heck the TT could have been bent.
    3. feral
      Ive bent them in flight on my 500 I had a sudden vibe problem.
      Turned out the tt was a S shape
    4. Mark Mickels
      Feral, the TT looks very straight to me, and I've got a pretty good eye for that sort of thing. The heli feels fine until it gets near the head speed for stunt one and two, and then the boom supports vibe so badly they are just a blur.
    5. feral
      Dude that odd real odd
      Have you replaced the mainshaft @Mark Mickels
    6. Mark Mickels
      The main shaft is running true. The blades have never touched the ground. The V-bar Vibe analyzer shows a vibe of 79 with the TT out at stunt one, and when I put in the TT it jumps to 1300. It has to be the TT because everything else has been checked and replaced if needed.
    7. feral
      Thats where id be putting my money on mate
    8. Mark Mickels
      IT has to be the TT. The V-bar vibe analyzer says the frequency equates to around 11,000 rpm.
    9. feral
      Wow
    10. feral
      It has to be twisting under load mate
    11. Mark Mickels
      If my friends remember to bring the parts to the field tomorrow, I should know. It's stuff like this that is really hard with this hobby!
      I think it might be the bearings on the TT, either flogged out or let go from the TT (or the rubber). A extra bearing in there might stop it twisting if that's the issue
      With the vibe at 11K it's somewhere in the tail drive for sure
      Good luck
    13. Mark Mickels
      The tt bearing feels fine, and there is no lateral play in it that I can notice. I'll probably take it to work with me and put an indicator on it to check for runout.
    14. simon
      and when you find the issue, post it so the pain is spared for others, thanks for taking one for the team
    15. Mark Mickels
      Thank you Sir Simon! I will indeed post when and if the issue is ever resolved. I feel like I'm chasing a phantom at the moment.
    16. simon
      feathering shaft in tail and tail bearings also worth a look
    17. Manyc
      I've had bearings that feel fine by hand but when under load go... swap out the tt bearing even if you think it feels fine.. I mean you have already got the tt out.. no extra effort and piece of mind it's not that
    18. Mark Mickels
      Just bought a new complete tail assembly. All new bearings, shaft, and hub and that didn't cure what ails me. It either has to be the TT or the boom, but like I posted this bird has never been crashed or even landed hard.
    19. Mark Mickels
      I agree, but I'm going to throw a whole new TT assembly in it at this point. I'm tired of messing about with it.
