GPS for your SK-720
Skookum Robotics has released a GPS module that turns the SK-720 into a Altitude/GPS unit. This unit only uses one extra 3 position switch for different flight modes. Position hold, altitude hold, and manual mode for all out 3D. The GPS can even be engaged inverted. The GPS also includes flight logging through Google maps to record and track flights. SK-GPS incorporates “Bail Out” function. You can set the unit for “flight floor and ceiling” heights that works for both single rotor and multirotors. This unit is set apart due to its high versatility from beginner to expert, smooth flight to hard core 3D. Aerial photographers and videographers can also benefit from this system.
Freatures
- Position hold, inverted capable.
- Alititude hold
- Return to home.
- Bail Out mode.
- Flight Logging.
Go here for more information.
Notice Skookum Gps
Discussion in 'Industry News' started by HeliGods, Jul 17, 2014.
