Blade has managed to pack everything that a hard core heli pilot would expect from a 700 size, pro-class heli into a 180 sized 3D machine that can be flown just about anywhere! The flybarless Blade 180 CFX features Spektrum H2060 Nanolite digital, rotary servos mounted within carbon fiber frames. Optimized servo geometry and famed AS3X technology combine to create confidence inspiring control that is almost kinetic. An included E-flite high-output 450mAh 3S 11.1V 30C Li-Po flight battery pumps plenty of high performance power through a Castle Creations Talon 15 brushless speed controller into the powerful, 4000Kv brushless outrunner motor. Other notable features include Rigid carbon fiber side frames, an efficient torque-tube drive tail supported on ball bearings,and an aluminum tail boom and one-piece tail case design. The only item not included with this bind-n-Fly heli are a minimum six channel Spektrum DSM2®/DSMX® transmitter and a Li-Po battery charger.
Heli pilots eager to bag this latest high performance heli from Blade can click through to Horizon Hobby for more information or to place a pre-order.
Specifications:
Size/Scale: 180
Rotor Type: Collective Pitch Single Rotor
Experience Level: Advanced
Completion Level: Bind-N-Fly® Basic
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
Number of Channels: 6
Type: Collective pitch flybarless electric helicopter
Swashplate Type: 120-degree CCPM
Construction: Carbon fiber frame sides with aluminum bearing/mounting blocks
Main Rotor Diameter: 14.17 in (360mm)
Main Blade Length: 6.06 in (154mm)
Main Blade Material: Plastic
Tail Rotor Diameter: 3.56 in (90.5mm)
Tail Rotor Blade Length: 1.77 in (45mm)
Blade 180 Cfx Bnf Basic
Discussion in 'Industry News' started by hgnimda, Oct 11, 2014.
