Info Check Out The Edge.... Sorry Switch Blades!
Discussion in 'The Chat Room' started by smakmeharder, Apr 27, 2015.
By smakmeharder on Apr 27, 2015 at 11:43 PM
    Berts new big bad blades! So would you make the switch from edge?
    1. Captain
      Captain Active Member
      Probably... I like my Edge blades.
    2. timmy
      timmy Member
      You would make the switch because Edge will sooner or later run out and be replaced with the new Switch blade paint scheme.
      Same same but different.
      I think the switch are edge molds but with different graphics.... would you agree @timmy ? I heard on a heli-nation that the CG was changed which would only concern the blade weighting. Other than than I believe they are the same blade shape
    4. timmy
      timmy Member
      I can tell you with 100% certainty they are the same mold.
    5. Captain
      I believe they are the same molds. Heard a rumour that the tips are changed. Not sure about that.
      sent from my Lumia 1320Win10 phone
      using Tapatalk.
      Thanks @timmy for the info. Might be a bit of spin regarding the tip change @Captain. That would take a bit of serious work to rework the molds, not to mention flight testing etc....
    7. ripcurlsurf
      ripcurlsurf Member
      Switch must had been a conflict of interest with SAB blades. Makes sense why Bert had to resign before releasing his blades
