Question? Help!!! With My Shuang Ma.
Discussion in 'The Chat Room' started by 255, Sep 2, 2017.
By 255 on Sep 2, 2017 at 12:02 AM
  1. 255
    255 Guest
    My Shuang ma 9101 double horse S has stopped flying after just two flights. The battery is fully charged and the LEDs work fine. The rear motor has lost significant power, after checking to see if both motors worked using a nine volt. Later the quadcopter would not even spin on either gear. The transmitter was working and the red LED on the motherboard indicated so. The tail blade was also not working even when the front and rear motors work. (the rear blade has it's own motor) Also any answers to intermittent signals would be great help.
    -Thank you, a concrned flyer.
      Sounds like an electrical or battery connector problem. Go through the entire helicopter - pay special attention to the power leads. Its difficult to diagnose without having the heli in front of you and playing around with leads. If there is no damage to the unit i would take it back under warranty. The usual response from manufacturers is that the helicopter has been in a crash - thats why its not working. But with no damage anywhere its very difficult to argue that point.
      Personally if your passionate and you want to learn RC heli, then the better type of helicopters are the 120sr. They are very easy to fly, will perform much better than the shuang.
      Then once you become even more experienced - move into collective pitch helicopters.
    2. ChopDrifter
      ChopDrifter Member
      Sep 3, 2017
      heli or quad???
    3. hgnimda
      I think it might be this model.
