Hmas Home Of Tnc Nsw Pilots Padded Cell
Discussion in 'Club Events / Club Talk' started by feral, Jun 30, 2014.
By feral on Jun 30, 2014 at 6:26 PM
    @jockstrap @sprog @ ripcurlsurf seeing as our club's heli members have doubled overnight we will have our own padded cell to talk shiz in there will be a few new dudes joining this thread over the next few days.
    By the way we need to name the heli strip.
    Get into it
    Go Team TriFlow
      Fearless bastard
    2. sprog
      sprog Member
      I found my balls thats all
    3. jockstrap
      Np Dude.. As Feral says - just go easy for a few flights..
      He can help show you how to change the feel and cyclic gains on the PC for you if you need to..
      When ready - move the cyclic servo balls in on the arms and then re-do the setup, will help with resolution on the gyro..
    4. feral
      Spewin they haven't dropped yet
    5. sprog
      sprog Member
      It feels just a bit dowy
    6. feral
      Up the agility
    7. sprog
      sprog Member
      Will it be more snappy then?
    8. feral
      Yep
    9. jockstrap
      The "style" will make it more snappy but the "agility" will make it quicker..
    10. feral
      True I always get them mixed up
    11. sprog
      sprog Member
      Im sorta understanding how it all works and what it means now
    12. jockstrap
      The "gyro Gain" for the cyclic (not the tail) can also be increased to make the head more snappy - just like increasing the tail gain does.. but lower it once/if the head starts to wobbly and only increase a few percent (say about 2-3%) at a time..
    13. sprog
      sprog Member
      So say if it gets a aileron wobble drop it down
    14. feral
      You'll get cyclic wobble on stops n shiz from the low servo res we need to move the balls in on the servo arms
    15. sprog
      sprog Member
      Is that something we can do out at the field
    16. jockstrap
      yep...
      The best way is to put it into a hover and then "flick" the aileron or elevator lever and let the spring return it to center real quick and thus give it a hard stop - if the ail or elev wobbles at the stop then lower the cyclic gain a few percent till it just stops - then you should have jsut about perfect cyclic gain.
    17. jockstrap
      better if you change all 3 of the balls at home and then bring to the field just for the PC setup - much quicker that way.
      Fly it for now and change on the night before you come to the field..
    18. sprog
      sprog Member
      Okay ill do it tomorrow after school
    19. jockstrap
      up to you - you maybe can fly it till friday and change then - unless Feral can help you on the PC before the weekend, not sure.. but it's up to you..
    20. sprog
      sprog Member
      Ill change em at home and probably give it a few more hovers and then change settings at the field so I dont frack that up
