Ikon Flybarless System – Aluminum Version
Discussion in 'Industry News' started by hgnimda, Jun 23, 2015.
By hgnimda on Jun 23, 2015 at 10:52 AM
    Bert Kammerer and MSH present a new leap in flybarless control. Every aspect of the iKON firmware has been fine-tuned and optimized, resulting in the highest level of flybarless performance. New vibration dampening technology isolates vibrations and creates rock solid flight that can be seen and felt. An easy to follow and simplified approach to flybarless setup allows pilots to spend less time tuning and more time flying. Built-in auto level technology allow recovery from any orientation, no matter if the aircraft is right side up or upside down. With support for both Spektrum DSM2 & DSMX satellite receivers and Futaba, pilots can use their favorite programmable transmitter. When using a Spektrum transmitter, two satellite ports create maximum redundancy & path diversity. All pins are now polarity protected, meaning an accidental application of power in the wrong polarity will not damage the unit.
    Features:
    • Latest Gyro Technology for Superb Performance
    • Vibration Cancellation Technology
    • Easy Setup via Built In Wizard
    • Separate Receiver Support, Futaba S-Bus & Spektrum DSMX & DSM2
    • Dual Spektrum Satellite Ports for Maximum Path Diversity
    • Built In Governor
    • (3) Flight Modes Available – Transmitter Adjustable via (3) Position Switch
    • Auto Leveling Technology
    • Firmware Updates Available via PC
    • Flight Mode Status LED Light
    • Onboard Mini USB Connector
    Specifications:
    • Cyclic servo frequency: up to 560Hz
    • Tail servo: 760uS/ 1520uS with up to 560Hz frequency
    • 34mm x 29mm x 14mm (LxWxH) / 13g (weight)
    [​IMG] [​IMG]
    Click through to HeliDirect for more information or to order
