Taking the guesswork out to create good results
The new KDE Direct Power System Thrust Calculator is an easy way to make sure you are getting the most efficient thrust measurements without the math. This is set up on their new designed website, and inegrated to the shopping cart. This is a simple as entering some small specs on the equipment you currently have, and adding these items to your cart from the calculator web page. simple and easy. This is mainly provided for the multirotor application, but it also can be used for any aircraft thrust value.
For more information on the calculator click here
Notice Kde Power System Thrust Calculator
Discussion in 'Industry News' started by HeliGods, Dec 18, 2014.
