Two great heli pilots fly the Synergy N7
RC heli pilots Matt Botos and Rob Cherry put their Synergy N7‘s in the box and throw down for the multiple GoPros at the Huntsville Heli Flyers Fun Fly 2014.
Synery N7 Specs:
- Neutral CG Fuel Tank – The Synergy N7 will stay balanced on the main shaft through out the entire flight!
- Modular Frame Design – The Synergy N7 is comprised of a front frame which is separated from the rear frame.
- Direct Drive CCPM – Modern flybarless electronics are designed with a direct to the swash linkage in mind.
- Giant CNC Delrin Helical Main Gear – The custom helical angle ensures smooth, quiet power transfer with minimal motor loading and instant recovery after a load.
- Mod 1.25 CNC Delrin Tail Drive Gears – These beefy gears will withstand even the most aggressive 3d pilot!
- Ultra light weight – Weighing in at 9.5lbs (without fuel)
- High Detail Canopy – A high-detail canopy stylized with unique scalloping and side molding,
- Adjustable Tail Ratio – The Synergy N7 comes stock with a 4.9:1 tail ratio that can be changed to 4.5:1 if you desire.
- Multiple Main Gear Ratios – The Synergy N7 comes with a 17 tooth pinion and a 139T main gear.
__________________
Notice Matt Botos And Rob Cherry In “the Box” – Synergy N7
Discussion in 'Industry News' started by HeliGods, May 31, 2014.
