Looking for an inexpensive charger that is compact? The great Team at HobbyKing have it. Get the details for this pocket charger as well as a couple other products by clicking through.
HobbyKing Pocket Rocket 80W 6S Balance Charger
$16.73
The HobbyKing Pocket Rocket 80W Balance Charger makes charging of your Lipoly batteries easier than ever before. Designed to be simple and easy to use, just select the cell type, charge current, and plug in your battery. Charging will start automatically. The Pocket Rocket can charge not just LiPoly batteries, but the LiFe, and Li-Ion types as well. Input power is from any 11~18V DC source through the included alligator leads.
Features:
• Simple to use
• Compact size
• Automatic charging of 2~6S batteries
• Up to 10A (max 80W) charge rates
• Includes XT60 charge lead
Specs:
Operating Voltage: 11~18V DC
Cell Type: LiPoly, LiFe, Li-Ion
Charge Power: 80W max
Charge Current: 10A max;
Balancing Current: 400mA/cell
Cell Count: 2~6 cell (7.4V~22.2V)
Dimensions: 116x77x30mm
Click HERE to place your order for the Pocket Rocket 80W 6S Balance Charger.
Turnigy USB Charging Adapter 2-6 Cell 2Amp Output (XT60) (US Warehouse)
$14.58
The Turnigy XT60 to USB charger is the Swiss-army knife of the digital age. This handy tool allows you to use any 2-7 cell LiPoly battery to charge virtually any device that uses a USB charge cable, and at a whopping 2000mAh output can even handle large tablets or two devices at once!! And if you head to your flying club with one of these there can’t be any more excuses the phone battery died, so you will be home on time for dinner and with that pint of milk.. Ummm wait forget I said that.
Features:
• Safe rapid charging
• Compact size, Durable construction
• 2~6S Lipoly input
• 5V/2000mAh USB output
• Convenient field charging of any USB based device
• Compatible with Apple devices
Specs:
USB Output: 5V/2000mAh
Input Voltage: DC 7~30V
Input Cut-Off Voltage: 2Cell and 3Cell
Click HERE to place your order for the USB Charging Adapter.
Turnigy Micro-X Quad-Copter DSM2 Compatible with FTDI Tool MWC (Multi-WII) (BNF) (US Warehouse)
$54.39
Introducing the Turnigy Micro-X Copter, the smallest BIG thing to come to the multi-rotor market.
The Micro-X Copter packs the power of Multi-Wii into a pocket size quad. This PCB based quad has an integrated DSM2 receiver, 6050 MPU and Atmel 328P processor working their magic. With additional provisions for future development, this one of the most stable and adaptable little quad copters on the market.
The Micro-X is a complete package and only requires a DSM2 compatible transmitter. The kit comes with 2 batteries, a charger, 2 sets of props and a matching FDTI tool, no need to fashion your own cables or hunt down the right spare battery.
For those that just want to bind and fly, the Micro-X comes preloaded and tuned with Multi-Wii. For the MWC gurus that want to play with PIDs and flight modes, the included FTDI tool lets you do just that. Binding to your DSM2 compatible transmitter is a snap, if the last bound transmitter is not found after 15 seconds the Micro-X goes into bind mode automatically.
For those that want rock solid performance, hackability and micro sized fun, this mini quad copter is a maximum must!
Features:
• 6050 MPU and 328P Atmel processer
• Built in DSM2 receiver
• 2 batteries included
• Charger included
• FTDI and cables included
• Upgradable
Specs:
Wheelbase: 100mm
MPU: 6050
Processor: Atmel 328p
Weight: 21g without battery
Battery: 300mah 3.7 li-poly (2 included)
Required:
A DSM2 capable 4ch transmitter 5ch recommended (for flight modes)
Note: This is a kit and does require some assembly.
Click HERE to place your order for the Micro-X Quadcopter.
Notice Product Info: Hobbyking Chargers And More
Discussion in 'Industry News' started by HeliGods, Apr 29, 2014.
