Getting ready for Spring and the warmer, drier weather? Before you head out, check out these new releases from Fusuno . . . . from canopies to FPV accessories. Click through to get the details.
Authorized AlexMos 3 Axis Sensor Gimbal Controller Set
FUP-GBC-01
$210.00
Product Details
(Authorized AlexMos V2.3b5 Firmware Simple Brushless Gimbal Controller w/ IMU and 3rd axis expansion board)
PRODUCT DESCRIPTION
AlexMos SimpleBGC V2.X “AlexMos” Simple Brushless Gimbal Controller board set is fully assembled and ready to use. Board have latest firmware designed by Alex Moskalenko. You can upload new software any time by onboard USB.
What’s NEW?
New option:
Skip gyro calibration at startup. With this option checked, board starts working immediately after power ON.
New menu command and GUI button for manual gyro calibration.
RC Map, RC Source moved to profiles. It allows to change RC control setting by switching profiles (warning: after firmware upgrade, old RC Map setting will be lost).
RC YAW axis control may be inverted now by specifying Min.angle > Max.angle, like for other axis (but this setting not used for limiting, just for inverting).
I2C errors monitoring: LED will blink when I2C error detected.
New option: gyro high sensitivity. It doubles sensitivity of the gyro, that equals to multiplying gains in the PID controller by 2.
It may be useful for big DSLR cameras.
The “Firmware Upgrade” tab in the GUI allows user to upload new firmware.
SPECIFICATIONS:
50*50mm size with 45*45mm mounting hole pattern for M3 screws.
Onboard USB.
Access to serial port, so a Bluetooth can also be hooked for easy tuning.
L6234 Motor drivers.
2 motors can be driven with this board.
Atmega 328P with Alexmos Bootloader preinstalled.
MPU6050 IMU included.
PRODUCT INCLUDED:
- IMU Board V2.
- Alex V2.X main board (2 axis controller).
- 3rd axis optional yaw expansion board.
- Sensor wire.
- 3rd wire.
For further information, please visit:
Download Firmware: Click Here!
Download Software: Click Here!
Download Driver: Click Here!
Download Manual: Click Here!
Authorized AlexMos 2 Axis Gimbal controller w/ sensor
FUP-GBC-02
$160.00
Product Details
2 axis Gimbal controller w/ sensor.
(Authorized AlexMos V2.3b5 Firmware Simple Brushless Gimbal Controller w/ IMU)
PRODUCT DESCRIPTION
What’s NEW?
New option:
SPECIFICATIONS:
Onboard USB.
PRODUCT INCLUDED:
IMU Board V2.
Sensor Wire.
FUSUNO ASSASSIN Fiberglass Airbrush Canopy Trex 500E Pro Combo
FUC-EP500CB-01
$65.00
Product Details
Product Include:
FUC-TX5001EPro – FUSUNO ASSASSIN Fiberglass Airbrush Canopy Trex 500E Pro x 1pc
FUP-361RE – FUSUNO Neon Red Fiberglass Horizontal/Vertical Fin Trex 500E Pro x 1pc
FUB-CFB-430BK – Fusuno 430mm Carbon Fiber Main Blade x 1 set
Also available in:
FUSUNO Crownie Airbrush Fiberglass canopy Trex 600E Pro
FUC-TX6021EPro
$65.00
FUSUNO Red Assassin Airbrush Fiberglass Canopy Gaui X4 II
FUC-GX406
$49.95
FUSUNO Rocket Airbrush Fiberglass Canopy Trex 450L Dominator
FUC-TXD4505
$29.99
Fusuno Wolfie Airbrush Fiberglass Canopy Goblin 700 Competition
FUC-GB700C-01
$85.50
Also available for the Goblin 700 Competition:
Rocket – FUC-GB700C-02
FUSUNO FPV Antenna / Helical Axial Mode 5.8 GHz RHCP
FUM-FPV05
$34.99
Product details
USAGE: Increased video range and clarity
DESCRIPTION:
Fusuno is pleased to introduce our helical antenna, designed for increasing video quality at maximum range. The helix is supported by a precision polycarbonate frame. Each antenna is hand tuned and impedance matched giving you a minimum of 12dBi return.
The antenna structure achieves a beam width of approximately 38 to 60 degrees. Our helical antennas have a minimum 12dBi gain across the entire 5.8GHz band.
Recommended for use on long range FPV video receivers FPV, and combined with a Skew Planar Wheel Antenna on the video transmitter will achieve maximum FPV range.
SPECIFICATIONS:
Frequency Range: 5725-5875MHz
Impedance: 50Ohm
VSWR: less than 1.5
Gain: 12dBi
Horizontal 3dB Beam Width: 38°
Vertical 3dB Beam Width: 38°
Front to Back Ratio: 15dB
Polarization: RHCP
Radiation: Omni
Maximum Power Input: 50W
Lighting Protection: Direct Ground
MECHANICAL SPECIFICATION:
Connector: SMA Female Connector
Also available:
For Fatshark and Immersion RC
FUM-FPV06
FUSUNO Rocket Airbrush Fiberglass Canopy Trex 800E Pro DFC
FUC-PRODFC8003
$79.00
FUSUNO Monte Carlo Airbrush Fiberglass Canopy Gaui X3
FUC-GX303
$29.99
FUSUNO Red Stratovarious Airbrush Fiberglass canopy Gaui X7 Formula
FUC-X7F003
$75.00
FUSUNO Monster Airbrush Fiberglass Canopy VooDoo 400
FUC-VD4003
$49.95
Notice Product Info: New Releases From Fusuno From Canopies To Fpv Accessories
Discussion in 'Industry News' started by HeliGods, Apr 26, 2014.
