Notice Product Info: The New Icharger 406duo
Discussion in 'Industry News' started by HeliGods, Mar 31, 2014.
By HeliGods on Mar 31, 2014 at 5:41 PM
    The weather is getting warmer and the days are getting longer. You know what that means? Yep, more flying time. Check out the new iCharger 406Duo. Continue through to get the details as well as the link to get your very own from the great Team at Progressive RC.
    ICHARGER 406DUO
    Item # 406DUO
    $299.99
    QUICK OVERVIEW
    High-power charger providing 40 amps on each of two channels – or combine the two outputs in parallel for up to 70 amp charge rates!
    Includes a free JST-XH balance board for each channel!
    Need flexibility in your charging? Nothing beats the convenience of a dual-port charger. Two independent charging channels in one compact unit lets you simultaneously work with batteries of different cell count , charging at up to 40A simultaneously – or if you want to go all out, combine the two channels and charge at up to 70A!
    With two JST-XH balance boards thrown in for free – one for each channel – you’ll be ready to go right away.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Specifications
    ● Input voltage range: 10-30V DC
    ● Input current limit: Total = 60A, Ch1/2 = 47A
    ● Maximum charge power: 1400W at >23.5V (1000W max. per channel)
    ● Charge current range: 0.05-40.0A per channel, or up to 70A in synchronous mode
    ● Discharge power: 80W per channel, or up to 140W in synchronous mode
    ● Maximum regenerative discharge: 1000W per channel, or up to 1400W in synchronous mode
    ● Current drain for balancing: 1.2A per channel, or up to 2.4A in synchronous mode
    ● USB charging port: 5V/1A current limiting protection 1.2A
    ● Balance accuracy: 10mV
    ● LiPo/LiIo/LiFe: 1-6 series per channel
    ● NiCd/NiMH battery cell count: 1-25 series per channel
    ● Pb battery cell count: 1-18 series per channel
    ● PC Connectivity: USB port
    ● Weight: 910g
    ● Dimensions (LxWxD): 171x118x59 mm
    ● Warranty: 1 year
    Click HERE to place your order with Progressive RC for the new iCharger 406Duo.
      This does look very very nice... At 40 Amps a channel, thats massive! 2000 watts combined.
